How to check storage space
27 Mar 2016
Bristolian living in Swindon
Hi all
I just want to know the best way to find out how much free space I have on my SSD? Is there any certain apps to get or just go onto disk management?
Also I've now got a few things added to my 'This PC' section, they appeared after windows done a repair after I installed a new motherboard and CPU...
They are:
System Reserved (D:) 578mb
Local Disk (E:) 96mb
Any help on the above matters will be appreciated
Cheers
It should be self-evident in my computer no? used vs free space? (this has been a basic thing since god knows when in windows).
If you're looking for an app to see where space is used up Treesize (there's a free version) can help see where space is being used.
If you're hitting "Quick Access" in Win 10 when you open explorer, you can set that back to the old style that opens on drive view (My Computer).
I am guessing you have partitioned your SSD into a load of partitions.
go into windows explorer and click on my PC and you will see how much space is left on each partition. That’s how much space you have left on SSD. Depend on the age and type of your SSD drive, filling them full is not a good idea as SSD have to perform TRIM to keep itself in tip top condition and also many drives operate a dynamic cache to boost write speed. When drive is too full that cache performance is diminished therefore the drive starts to get slow.
Thought this was going to be a 1st time poster/troll thread....
How long have you been using pcs for? 2 days?
Seems like the System Reserved and Recovery partitions have been assigned drive letters, they're usually hidden and not assigned a drive letter.
Cheers for the replies
@Haze I've been using and building for years it's just I wasn't sure as it had all the different sections when I looked into the SSD.. As listed above, just doesn't seem normal having them as they wasn't there before
Those are partitions that are used by Windows that are normally hidden. You can go into disk management and remove the drive letters from them.
