How to clean: an idiot's guide by a wannabe.
Cool beans - I'm afraid I'm not much of a runner. Do you go to any of the Cambs gyms?
I used to go to DWs because it had a pool so workout then swim, but then decided I didn't like paying.
Now? I'm thinking about going back to a gym; I don't lift for bulk, just strength and endurance, and I miss it actually :).
Ha ha :D
No I didn't get any unfortunately, yesterday was a little busy.
I'm going to assume that the main problems came from the fact that I had squatted heavy the day before and was just generally fatigued. I was finding it difficult to get the connection with the upper thigh, and I guess it was mostly that I was just missing extension.
Having also done some snatches yesterday I'm not surprised I didn't get on with them very well :). I might have another go tomorrow and I'll try to get some vids ;).
Nice guide so far. I power clean about 70kg without a problem, but I think my technique is terrible. I seem to generate my power from a vertical jump rather than from a forward hip drive.
I'm trying to work out where your "gym at work" is, I'm guessing the guy's t shirt in the background is a clue?
The only decent gym I've used in Cambridge (aside from a couple of the colleges) is a martial arts gym. My current gym is fairly terrible.
Excellent, now do the 2nd part.... The jerk / power jerk :p
Split jerk? Fine. Power jerks are for guys with much bigger triceps, lats and delts than me! ;)
The only decent gym I've used in Cambridge (aside from a couple of the colleges) is a martial arts gym. MY current gym is fairly terrible.
That's the trick - I'm sure a fair number of people on here could clean/snatch a lot more than me if they had the same coaching that I do. Instructor hax? :eek: :cool:
And yes - I work at ARM. :)
Just read thru all of this and what a fascinating read. Might give it a go on Friday when Steedie and Chris come up!
I definitely don't use any of this hip drive in my cleans :p
This weekend, I will mostly be working on a "how to jerk" addition to this thread.
For now, have some floor work.
The clean pull...
This is where strength/power work comes into Olympic lifting. However, to do this properly, you need to make sure you have the basics of core stability, hip drive and shrug working well (to the point where your lower back doesn't hurt when you clean).
The 'clean pull' is essentially a clean from the floor with a weight that is too great for you to get it to front rack. It involves three stages:
- First pull: a highly exaggerated deadlift with the thorax in a fixed position;
- Scoop->hip drive: bar passes knee, gets dragged up your thighs and WHACK!
- Second pull: the power shrug.
The first pull.
1) load the bar with 20kg (2*10kg) and get yourself into a 'standard' deadlift position with the bar over the bridge of your foot.
2) Keeping your weight over your heels (this is where ankle mobility comes in), lean right over the bar until your shoulders are almost past it, and pinch your scaps, and brace your core like your life depends on it.
3) Pull. Keeping your torso fixed, shoulders hard back, lift the bar with your hamstrings. ;) This is done by pulling your knees back. This should wind you up in an interesting position, with your knees almost straight, the bar just below your knee and with your torso at a severe angle. Recognise it from your hip drive work?
The key thing with the first pull is keeping your torso as tight as you can and shoulders right over the bar - I can't emphasise this enough.
Scoop, hip drive and second pull.
This is essentially the same as your standard power clean/hip clean/whatever. However, as the weight is too great, you will simply be driving your hips through and shrugging hard.
Do not worry about the weight (assuming you can get it past your first pull): you might think it will move more slowly (and it will at first), but in the end it will be zipping almost as fast as your regular loads.
However, you MUST make sure your driving from your hips rather than lower back for these. If you pull from your back, you might as well be doing a bad deadlift and your in for all kinds of pain. Trust me: I've done it. And it is pretty uncomfortable. :D
So what does this look like?
Notice I'm using straps. Clean pulls can put an enormous strain on your grip because of the hip drive power (not force!) involved. Straps make this a lot easier to bear.
Also notice how my torso dips slightly during the first pull, showing how I need to keep my core more stable and shoulders pinned harder.
WARNING: for the first few sessions, this exercise will give you the most uber hamstring and trap pump you have probably ever felt. It's fricking awesome. :D
That's my gym kit. :D
No - it was the original recording from last week when MoNkeE asked for a demo (this was after I'd changed from the gym session).
And it's generally what I wear in the office.
Ha awesome!
That's a nice post. I'm going to have a go at some more stuff from the floor next week so I will be referring to this :). Thanks brah!
