Due to an overwhelming lack of requests to update this thread, and a slow day at work, I've decided to have a play. I will be updating the OP with the
slightly less idiotic idiot's guide to clean/snatch/whatever as the original only went through getting the
hip draaaaaahve working.
So, fun stuff that derives from Olympic lifting. What are some exercises that people may/may not find useful in their bodybuilding/power lifting regimes?
JERK DRIVE
Essentially, the
power part of the jerk which may or may not be used as part of a full power/split jerk. This exercise is useful for them, sure, but if you athlete at all, performing this exercise generates more power than any other in either the clean'n'jerk or snatch sequences.
It's great for balance, nervous system blitzing and shoulder/upper back/core stability. And it will be an interesting qualifier for you to determine how much oomph you're getting from your legs in either Push Press or anything leg-related.
How to do this?
1) Front rack the bar, and pin your shoulders back in the 'stable/neutral' position. What you'll get is your elbows slightly down and the bar resting closer to your clavicles than in the regular front rack.
2) Prep phase by giving your knees that 5 degree bend and sink back into your hips as far as you can comfortably hold the bar.
3) With a core of steel, drive through your heels and get those hips through!
4) The bar should lift off your shoulders, so guide it up and down, giving at your hips/knees to catch it.
5) Rinse and repeat. I generally go for low reps on jerks because they are horrendous and make my CNS go nuts...
A fun point: I read a study on jerk technique, which noted that lifters whose dip and drive was as fast as they could manage achieved something like 50% spring reflex from the bar itself, meaning greater lift, whereas a pause at the bottom of the 'dip' caused all that elastic energy to be lost as heat...
SNATCH/CLEAN SECOND PULLS
If you want something to fry your glutes and traps, give these a shot with something heavy. Snatch grip will murder your entire upper back, and the cleans will decimate your traps.
Practically speaking, weightlifting studies note a statistical correlation between the top lifters and the lack of heavy pulls in their respective regimes, essentially on a point of specificity: want to get good at Olympic lifting? Do Olympic lifting. The motor pattern of pulls is slightly different to the full lifts, so doesn't serve a direct purpose, but is awesome for general explosive powaaaah!... and huge traps.
How to do this?
1) Set your top position with the bar gripped for snatch/clean;
2) Give your knees 5 degrees and sink back into your hips, pushing them back as far as they will go, keeping your shoulders in front of the bar.
3) Depending on how far you want to drive, sink as low as you need. I would stop above the knee unless you want to actually try Olympic lifting...
4) Assume your drive position with your core braced.
5) Keeping your shoulders pinned and core locked tight, drive up through your heels and slam your hips/thighs through the bar.
6) Shrug. Not the type that will make you go blind, but yank your elbows straight up as hard and fast as they will go. An ideal end position is with the humerus parallel to the floor (90 degrees from your torso). If you're in the right place, you should be leaning ever-so-slightly backwards.
I'd suggest using straps for these. Particularly if using a snatch grip, as the bar will try to eat your hands. Good luck if you're fortunate enough to have an Eleiko bar, as I understand these actually have teeth. Also, when you get your shoulders over the bar, you should really feel a biiiiiig pull in your lats: this will tell you your shoulders are over the bar enough.
FIRST PULL
Explained in a previous post, these are great for learning how to get into a decent and stable position to drive from, either for a deadlift or clean/snatch. If you do them heavy, your hamstrings, calves, core and shoulders will hate you forever.
You can turn them into a more interesting form of torture by using a slightly lighter weight and performing 6-8 reps with a controlled negative (knees come forward) and not letting the bar touch the ground... but make sure your core is up to it. This hurts. A lot.
The above movement will really tax all the muscles outlined above and particularly the upper back if using a snatch grip...
As posted, I'll see if I can get videos of these so that you can see what I'm actually talking about... Enjoy, and good luck!
