How to connect controller to PC?
Make sure you got all you need if you buy a wired 360, I got one in a deal with my graphics card and has a pc port, but it looks like I need an adapter as I have no idea how to connect.
I did buy this used mind.
Any cheap 360 controller on fleabay will work plug and play with PC, have bought loads of them and they will obviously say PC also on them, you can get one for about £7, bought one only the other week myself.
Forget the ps4 controller it is a huge nightmare. Use the Xbox one. Use the cable you charge the controller with and plug it into the USB hole.
