This is an odd one. It's definitely not CPU or RAM. It's presumably not the GFX, as it happened with a previous card. It's probably not the PSU, as it's a decent unit and you don't actually get any crashes.
It could potentially be the motherboard, but Furmark runs fine, which makes it less likely. I'm leaning towards a software issue. Do you have any spare hard drives lying around that could be used for a test re-install of XP?
Does this problem happen in all games, or just some?
