Does anyone know whats the stock voltage on the MSI R7850? At the moment when using GPU tweak, its defaulted at 1210. Safe?
depends on each gpu,some use more some use less,mine is 1.135v stock v
That seems very high for a stock voltage !Does anyone know whats the stock voltage on the MSI R7850? At the moment when using GPU tweak, its defaulted at 1210. Safe?
You need to get ASUS GPU Tweak as the others don't let you control the voltage.
What I did first of all was just stuck mine up to 1200MHz straight away and 1.195v and ran Heaven to see if it could handle it, and I tweaked around from there.
Ended up sticking with the 1200MHz clock and got it down to 1.175v on my MSI TF3.
I'm pretty sure GPU tweak doesn't read the voltage correctly on MSI cards. I have an MSI TF IV and whatever I set the voltage to in Afterburner, GPU tweak and Trixx show 1210 as the voltage. I know that the voltage adjustments in Afterburner are working due to increased OC stability and temperature. Afterburner should have the correct reading.
I tried that and was greeted by my screens turning weird colours with lines running across. Would you recommend I try upping the core bit by bit instead?
Thanks
cmd-
Umm, at 1210/5500/1180 I get a lower heaven score than 1220/5500/1205, why is that? 1444 vs 1425
It seems like going past 1220/5500 to 1230/5500 and 1235/5500 brings heaven benchies down from 1466 to 1325, I wonder why, will post more screenies soon
Has anyone experienced artefacts on the desktop and in games with this card at standard clocks?
