No, you missread my post..
My stock voltage is 1138mV, and my OC voltage is 1220mV..
and having it at 1200/1400 put the voltage up to 1220mV"
And yes, I do have the same card as you, an Asus 7850 DC2.. And my 65º max temps are at full load AND OCed.. Not at stock..
My guess, you have a poor case airflow and high ambient temps..
Maybe a mistake, but you have only one intake fan "at the top"????..
Heat rises, so having it as an intake it's probably a fail..
Maybe it's time to do a fan readjust in your case.. Theoretically, you should have fans getting fresh air at front and side, and having pull hot air out at top and back... Maybe there's your issue..
This card runs very cool compared to stock ones.. Your temps aren't bad at all, just maybe could run cooler..
Best regards..
