How to overclock a 7850 past 1050MHz?
Does anyone know how to disable the idle slow-down? Every time that i get the blue horizontal line problem is actually when i'm just browsing or the like and when the card is on idle clocks.
Hi i was trying to over clock via trixx and ccc. I cant seem to change my voltage to the card its stuck on 1.075v what ever i change li to.
edit sorry found out how to scroll
Use MSI Afterburner to set separate 2D and 3D profiles and set both to the same speeds.
Just finished some testing on Unigine. I'm happy to settle with the following for a daily clock. When the card gets a bit older I might try and push it further.
MSI TF3
£180.00
77.8% ASCI
1200/5004Mhz
1.185V
71 degree C
Max stable overclock of 1235mhz on the core clock and 5500mhz on the memory clock at 1.225v. This is a HIS IceQ X 7850 with an ASIC of 77%. :)
Stock speeds...
Overclocked speeds...
MSI TF3
£180.00
77.8% ASCI
1200/5004Mhz
1.185V
71 degree C
Jesus.. i can't believe how high you guys can go when i can't even get over 1100 on the core with stock memory with 80.5% ASIC! If i get the voltage over 1.150 the colors of stuff in Windows turn red and gets blocky too, so i can't go higher there.
This whole ASIC thing clearly isn't the best indicator. You two can get higher than i've seen people in the 90% range do.
What GPU tool are you using?
What manufacturer or card?
Also version of catalyst?
So cant wait for a months time when I have the funds to get one of these bad boys.
Unless the 660 is beastly I am totally sold on a 7850
