gonna do fresh install first
I'm thinking of going for one of the VTX 7850 as thats the one that 555BUK had the really good clocks with (1200 on the core is not to be sniffed at), but do any of the other brands clock just as well? if not then I'll spring for a VTX versh. I reckon it'd be helpful if people who bought these cards would say which manufacturer they bought and what clocks they get.
I also noticed its gone up in price.
I've found something very interesting
My standard OC is as follows:
Core 1150
memory 5800
1.215v
My min fps in the heaven benchmark was 14fps, however.....by increasing the core to 1160 gave a min fps of 26fps. That's a 12fps increase for only an extra 10 on the core.
The avg and max didn't change however. Thought it was quite interesting how a small OC of 10 on the core increasing the min fps so much
I have the MSI and it's sat at 1290/5800 no fuss.
Now on preorder mate. Its looking like I'll go for the VTX versh atm as its one of the cheapest and its the same as the one 555BUK used.![]()
welshdragon has a VTX but think he may be struggling with high clocks. Could be something else as he's doing a fresh windows install.
I want an MSI![]()
ouch, and I thought I had a bad clocker
If you put the memory to full in CCC then that's why it crashed. High memory needs extra volts. If you just put the core 1050 though then you got a stinker
For people having instability issues, try leaving the VRAM at stock levels and just overclock the GPU. Once you find the max GPU clock on stock voltages, start upping the volts by 0.025v increments and up the clocks again. This will help you identify the best balance between clock speed, heat, and noise.
Once you have obtained your max/ideal GPU speed, start upping the memory.
My card clocked as follows.
*Max stable core was 1275MHx with memory at 5800MHz.
*Max stable memory was 6000MHz with core at 1150MHz
*Max for benching was 1325MHz / 6000MHz but this is VERY FAR from stable and needed 100% fan.
*At stock core 860MHz, memory was stable at 6200MHz.
*24/7 clocks were set at = 1200MHz / 5800MHz.
Max stable core and max stable memory would not co-exist on my card. I had to drop one to keep the other. Also, over-volt protection would cut in if I set clocks and voltage too high. This dramatically reduced fps.
Core clocks provide greater gains than memory clocks (atleash within Heaven, 3DMark11 & BF3).
1150MHz / 5600 MHz @ 1.150v should be safe for most cards.
will be looking to get a new card when i get back off holiday, i play at 1080p. How do one of these cards at 1200mhz compare to a 580 at say 900mhz? Can get a good quiet non reference 580 for about 200 quid second hand and its very tempting.
get the 580
There's no guarantee you'll hit 1200 on a 7850. Mine can'talthough it will do 1150 no problems
