Fresh install of Windows 8 on my spanking new SSD.
Cat 12.3 drivers in, with the corresponding CAP 1.
Sliders to 1050 / 5600 on stock volts for now.
Heaven is on a loop now and all seems well. ~97% GPU usage and the fan is at 51% / 68oC.
The old Q6600 doesn't seem to be holding it back, at least in Heaven anyway. Obviously games may be a different story!
When you right click on the ccc in the task centre is it normal to see your card listed 5 times?
I have never oc a gpu before in my life....
I always just leave them as I am scared to screw things up.
Is it really easy to overclock these cards?
I remember once I tried with my 3870x2, using the ccc to overclock, but somehow managed to screw something up to the point where the refresh rate was stuck at 59hz.... that scared the **** out of me, and so I vowed never to attempt to overclock again.
However with these cards quite cheap and if they overclock well then it may be worth saving money and getting one of these over a 7870 or a 7950....
Thing is at these kind of overclokcs 24/7 are they stable? Can you just set the clocks and be done with it, or do you always have to set the clocks whilst running programs....
All I want is to overclokc it and thenforget.. dont want programs running at boot up etc..
This is driving me spare. Can't see what is going wrong here. At this rate I'll be back to my 570
1275MHz was only stable with fan on 80% and 1.2v. Temps and noise are far too hot on the reference cooler to keep it that high. It was completely stable (survived looped Heaven and BF3), but the cost to my ears and risk of a quick death were far too high.Show Off!!!
I assume all the above * points were with max volts
Just as well I didn't use NewTek’s LightWave, Autodesk’s 3ds Max, or play Starcraft at STOCK setting's thenThe plot thickens, taken from toms hardware:
Unfortunately, our in-depth evaluations in two different labs at opposite ends of the world turned up a handful of unexpected issues, too. Igor Wallsosek in our German office reports back with a lot of Radeon HD 7850-related issues: NewTek’s LightWave crashes with 4x AA or higher, Autodesk’s 3ds Max crashes in DirectX mode, and the card is incapable of running StarCraft II at its stock clocks
Oh dear. WHy did I not see this before? I wonder if this is a driver issue?
24/7 clocks of 1200MHz requires 1.150v.
Yup, I've started running those settings for 24/7 myself.
1290 is totally stable at 1.225V but the voltage increase to go from 1200 -> 1290 isn't worth the extra heat and noise for me.
Running 1200 @ 1.15V I get 67C max and 49% fan, which is lovely.
@welshdragon - Yup that just sounds like driver teething issues to me.
mmmmm, I'm getting 65c / 49% fan on 1.225v? Perhaps that's due to the twin fans on the sapphire?
