- 30 Aug 2009
I assume you've done the following:
Installed either 12.3 or 12.4 (I don't think it matters which one really) reboot.
installed Asus tweak 2.0.8.3. reboot
select "advance mode" by selecting the middle button of the three small vertically buttons placed at the bottom lefthand side of the tool window.
select "settings" from the four larger options above these three little buttons.
From the window that opens, select "tuning" from the five options running across the top of this pane.
Towards the bottom of the pane, there'll be an unticked option called "overclocking range enhancement", select this option by putting a tick in it's box,
While you're in there, towards the top of the pane you're in, theres atick option to enable "GPU voltage", put a tick in the box to enable this option.
Onve you've done all that, select apply.
the screen will flicker and go black for a few seconds, then appear normally.
Select "Tuning" from the top of the line of options running vertically on the lefthand side of the pane and ....voila, you should have the increased overclocking range available to you.
Hope this helps, I can't put anymore comprehensively![]()
Very comprehensive, but yes, I have done all of that already. I cleared out the last vestiges of the nVIDIA driver and physics stuff but no luck there.
