Just a thanks to everyone in this thread for the tips
got my 7850 a few days ago and got it nicely OC'd to 1200/5800, will fiddle around with it further at a later date but just a quick message for the indirect help in choosing the card!
Yours might be about the same as mine, needs voltage higher than everyone elses to get even a reasonable o/clock. If you can do 1150 at say, 1.175v core, then thats in the same ballpark as me, give or take a few millivolts. Your temps appear to be reversed with mine, I get higher in game temps than when benching, heaven that is. My temps on the other hand are extremely low as I've got a gelid cooler on mine which gives storming cooling, never seen me card go above 45c-50c load since putting this on.![]()
Yeah, I need 1.170 to get 1150. I think the reason the temps weren't very high in BF3 is that my CPU could have been the bottleneck. In Crysis it went up to 77. Can anyone tell me if this temperature is safe?
the temps are relatively safe but if it were me I'd like them to be a little lower. My main concern would be how hot are the voltage regulators getting? I reckon these limit overclocks stability due to running hotter than normal when over volting is used. I found I was stable at 1175/ 5800 when I fitted some sinks to mine a few days back, whereas before I could barely get 1125/ 5800 when gaming.
Gibbo just recently said the 660 probably won't be coming anytime soon and the 670 will start out at 300+ so screw waiting, I am quite ready to buy.
Now around here (Latvia) the MSI 7850 goes for 200 quid, while its bigger brother stands at 275. Reading this here thread, am I correct in assuming the difference is no way worth 75 ? Problem is, I reluctantly step down from the 7950 as it is, another step down feels a bit silly considering it is going into a decent rig and I can happily afford a 7870. However, I -am- a sucker for a good deal and certainly no stranger to overclocking.
Hoping for someone to slap me with a convincing argument to seal the deal, then I can join in on the clockin' and benchin' fun around here.![]()
If you want more performance, perhaps a pair? Or is this more than you're willing to spend?
If you wanted a quieter card that should clock to 1200 or above, which most Twin Frozr or Sapphire dual fan cards seem to do, you'd be paying £200+ so might as well pay another £45 and get the 7870.
Perhaps going for a 7850 now and looking to buy another one later down the road is the most prudent course of action.
Just so you know, that power slider in CCC is nothing to do with GPU voltage. It's how much power the card is allowed to draw over its normal TDP.
