https://www.symbiansigned.com/app/page/public/openSignedOnline.do
This line and the newest version of Rotateme allows it to be signed here. If your having problems email me on trust ill do it for you. Takes two mins this way.
If you've got the time, the hack does work. Then any app works straight away after that
Yes, major hastle. But I really wanted rotateme.
For anyone considering it this guide was pretty easy to follow.
Thanks mate, I assume that this is for the n95 8 gig due to the title of the tread?
Yea, I've got the 8Gb one
Pdog: You have found your port then yea?
Not sure what that error message is. I've no knowledge of what I was doing, just followed it step by step with another guide as well from a from ipmart forums. You have to sign up there and this guide seemed to have everything in it anyway.
