Surely after 18 months of driving you would be able to tell if it was FWD or not..?
My brother has been driving for years and was shocked when I told him his Toyota Corrolla (N reg) and almost all new cars are FWD.
That isnt possible with haldex unless the front wheels are loosing grip. The rear power is taken of the front diff so it can only share what the front diff has not transfer more power aft than what is given to the front. If all wheels have grip the max is still only 50/50.
correct, to a point. the gen 2 haldex which was fitted to the mk4 r32 wouldnt allow more than 50% power to the rear wheels.
however, the gen3 haldex thats on the mk5, coupled with the haldex controller thats available allows 3 modes - stock, sport and race. race mode makes the car permanently rear wheel biased.
you can read about it here : http://www.hpamotorsports.com/haldex.htm
The system cannot send more power to the back wheels than is available at the front. The haldex unit taps the power of from the front diff it can only ever share that power. Torque bias can be greater than at the front but only when the front wheels are unable to put all the power available to them onto the road, then the rears have more grip and hence more torque at the rear wheels. With the haldex clutch packs fully closed then the front and rear axles are directly connected together in effect. The HPA controller acts more agressively than the standard controller and has the 3 different modes to make it act in varying degrees of agressiveness but again it can only share what is sent to the front diff. It cannot send more power to the rear wheels because of the way its designed and where it taps power from, to do that you need a centre diff to distribute power. The HPA controller makes the car act with more rear bias than standard but it cant make the car more rwd biased than front.
Mk4 R32 uses gen1 Haldex same as the original S3 and Audi A3s. The gen2 haldex was fitted to all 8P A3s and S3s up until the face lift when the Gen 3 system was fitted. Most mk5 R32s will be gen2 and im not sure if they fitted gen 3 to them at the same time they did the Audis.
The link I provided shows you're wrong.
The max split via haldex is not 50/50, even when all four wheels have grip, because the simple act of putting power to the front wheels creates slip, and as the loading on the wheels changes (especially under hard acceleration), haldex can happily put 60-70% of the torque to the back wheels without actual wheelspin from the front. Under normal cruising conditions, 40-45% of torque is going to the back.
The other issue that suggests this is the case is that the tyres on my S3 (which need changing) have all worn equally. If there was a heavy front bias to power, as well as steering, the front tyres would wear much more quickly.
Do you think you understand how Haldex works better than the people who created it? Because your explaination of the system and it's capabilities seems to share very little with theirs
Dolph I know very well how the system works and was having the agruements on here about the torque split before you had your S3.
That just makes you persistant, not correct.
How do you explain the direct conflict between your position and that of haldex regarding how much torque can be transferred to the rear?
HUGE can of worms all over my desk, they've gone all over the place!
I always put the newest tyres on the front, simply because a FWD car requires more grip at the front end so you can turn and still put power down without understeering in the wet.
I prefer oversteer to understeer and if your car has ESP then its a no brainer FWD = newest on front, RWD = Newest on back.
