With the Spitfire, bullets would fly everywhere like a scattergun.
I was under the impression the convergence could be setup identically between the Hurricane and Spitfire.
The actual position on the wing, aslong as harmonisation is possible which it was, doesn't matter much at engagement ranges: https://en.wikipedia.org/wiki/Gun_harmonisation
EDIT:
Furthermore, the physical arrangement of guns in the wing had an effect on the convergence pattern. The Spitfire's guns were spaced relatively far apart in each wing, which meant that their gunfire was more dispersed before and after the range of greatest convergence. The Hurricane's guns were closely spaced, allowing more confidence that a grouping of bullets from one wing would cause heavy damage, even if the other wing's bullets missed the target. While Spitfire squadrons might converge their wing guns at a different distance for each left–right pair, to give a deeper envelope of damage, Hurricane squadrons usually aligned the guns in each wing to shoot nearly parallel, with all gunfire coming together at the same range. As a result, the Hurricane outperformed the Spitfire in delivering damage to German bombers during the Battle of Britain.
Seems to be as much as anything down to the preferences of the different pilots between the different air planes as much as any inherent difference.
