Okay no problem. Thanks for the help anyway.Úlfhednar said:I never disagreed mate, was just trying to find any way I could to make it cheaper for to upgrade and possibly increase the power at the same time.
D'you play Oblivion?
Kent said:Nope, it is 754. Everything in this comp atm is standard and was bought about 3 years ago, so I brought it upon myself to upgrade it as I wanted to start gaming properly on the PC.
Oh, well it's a Trigem IM845GL board.DaveyD said:You are mistaken, if it's an intel, it's definately not a S754.
Aye I do, and it runs nicely on high settings on my system in 1440x900 but I imagine that an X1600 would need a serious resolution drop to cope (800x600 or so, but I hope I am wrong.)Kent said:D'you play Oblivion?
On all high it probably would be 800x600. Someone posted and said I should get away with 1024x768 on medium-high settings, which i'd rather do I think.Úlfhednar said:Aye I do, and it runs nicely on high settings on my system in 1440x900 but I imagine that an X1600 would need a serious resolution drop to cope (800x600 or so, but I hope I am wrong.)
What's with the rolleyes? I didn't realise that you needed this explaining to you. I apologise for assuming that you knew and yes, I did mean 1024*768.Kent said:Thanks, and is the resolution you're reffering to 1024x768?![]()
I was rolling my eyes at my own lack of knowledge, not yours.spinneR~uk said:What's with the rolleyes? I didn't realise that you needed this explaining to you. I apologise for assuming that you knew and yes, I did mean 1024*768.![]()
