HTPC Project [Build Log]
Looking really nice!
Thanks
It is looking good
Also did you find it difficult to rewire your fans as per your diagram above?
Actually with a bit of soldering experience and a soldering iron stand it was surprisingly easy.
Just trim down an ATX wire and solder 3 male fan wires to it, twice
Then a single female -> male fan wire will serve as the RPM wire
And a female to 3 male fan wire will do the PWM.
I measured them up to the same length as the wires to the same connecter and then soldered them all together.
It was the sleeving that I had issues with... but that's all done (except I need 1 more black 4 pin fan header....)
acfe231b-06b2-468b-a255-391c8e839027_zpsotrhtmsg.jpg~original
I also realised I could run my slimline Blu-Ray power connector off the same ATX connector
There haven't been any updates in a while because I've had a lot going on with everything else...
Well my crimps have finally turned up:
D2E02938-857D-4C19-86B2-2AD9C8709CA2_zpswmb3fbty.jpg~original
This allowed me to shorten the cables on the last fan without soldering it...
C2DA1AAA-EA23-4C85-A5A0-C22C5164AC3C_zpsvhgaa1ow.jpg~original
And install it:
B727D700-D5DF-48C3-A013-11187E239B3F_zpsgaxqx9f6.jpg~original
I might have done some of the cabling a little short, and now I've got the tools to do so I might redo it properly.
This is a top down view, showing the new cabling and the new fan installed at the front of the case.
08253C7D-8E18-471C-9D54-9D3FA7D11164_zpsepisopqt.jpg~original
I removed the 6 wire combs and replaced them with 12's
5605BF03-77E1-4B01-A119-F81B7371F26E_zpsvwwwetpr.jpg~original
And I started crimping some wires:
885D3B15-D2B5-46DA-9089-D44F95A2917C_zpswfaacu4p.jpg~original
And did my first dual wire ATX cable:
D61FF823-370A-462A-8394-C8B21C156171_zpssr6knpvw.jpg~original
That took me until about 2am, so I decided to get some sleep...
There are 2 photos which are not playing ball, Photobucket doesn't want to let me resize AND rotate, it's one or the other.
I'll retake them later.
Thanks, but any idea where I could purchase said handle? Have googled, can only see stuff from USA...
Since I haven't had much chance to work on this in the last few days, I thought I could at least upload an updated spec sheet for it:
Main Build
1 x Intel Core i5-4690K 3.50GHz (Devil's Canyon) Socket LGA1150 Processor - Retail £199.99
1 x Asus Maximus VII Impact Intel Z97 (Socket 1150) DDR3 Mini ITX Motherboard £179.99
1 x Corsair Vengeance Pro Silver 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Memory Kit (CMY8GX3M2A1600C9) £64.99
1 x Samsung SM951 128GB M.2 PCI-e Gen3 8Gbps x 4 Solid State Drive (MZHPV128HDGM-00000) £89.99
1 x SilverStone NightJar 520W Zero dBA "80+ Plus Platinum" Fanless Power Supply (SST-NJ520) £109.99
1 x Corsair Obsidian Series 250D Mini ITX Compact Gaming Case - Black (CC-9011047-WW) £75.95
1 x Silverstone 5.25" Slim ODD Bay with Internal 2.5" Bay - Black (SST-FP58B) £12.49
1 x LiteOn DL-4ETS Slimline Blu-ray Burner SATA Slot Loading - Black £59.99
GPU
1 x EVGA GeForce GTX 970 SC ACX 2.0 4096MB GDDR5 PCI-Express Graphics Card (04G-P4-2974-KR) £289.99
1 x EK Water Blocks EK-FC970 GTX Backplate - Nickel £20.99
1 x EK Water Blocks EK-FC970 GTX - Nickel £79.99
Water Cooling
1 x EK Water Blocks EK-FB ASUS M6I - Acetal+Nickel (Original CSQ) £49.99
1 x EK Water Blocks EK-D5 Vario X-RES 100 (incl. pump) £105.95
1 x Hardware Labs Black ICE Radiator GT Stealth 240 - XFlow £36.98
8 x EK Water Blocks EK-HDC Fitting 12mm G1/4 - Blue £5.45 (£43.60)
1 x Corsair Fan, SP120 PWM High Pressure Fan 4 pin, Dual Pack (CO-9050014-WW) £25.00
1 x Be Quiet! Shadow Wings Fan PWM - 92mm £8.99
5 x E22 Ultra Clear 12/10 Hard Acrylic Tubing 500mm Length £4.99 (£24.95)
Liquid
1 x Mayhems Pastel - Ice White Coolant 1L £14.99
1 x Mayhems Dye Ocean Blue 15ml £5.48
Total : £1,500.28
Main Build
GPU
Water Cooling Loop
Liquid
Sorry real life got in the way of this build unfortunately.
Well after repeatedly getting fed up with not being able to bend the acrylic nicely I finally decided to switch manufacturer / distributer.
I bought 2m of EKHD Acrylic tubing, which arrived yesterday, and finished off the build last night.
I just need to colour match the liquid now, I will upload some photos once I get home tonight.
A little later than promised...
a42b03c8-a28f-4e44-aa7a-26273cfa1664_zpsihsrtuvm.jpg~original
99dd86ac-2530-4419-8b68-89a3f2bf4963_zpspvwexpwz.jpg~original
I'm going to redo a little of the cabling because it's a little messy, and I still need to work on colour matching the coolant.
I also want to take some shots with better lighting and a deacent camera in a few days and get them uploaded...
Well done on the bends I'm there myself finding it very difficult to get right. Yours look very neat considering some of the bends look very tight.
