Im looking at getting a pair of 380s, can you remove the Mic when you are not using it ie listening to music ? or is it permanently fixed to the headset?.
After reading a few reviews it seems the mic cant be removed however it seems the mic can be adjusted to move upwards out of the way, can anyone confirm this please?
Those 380's could be a winner. I used to have a pair of 367's and for the money, I think they are unbeatable. Couple of good reviews appearing on the web as well.
I think you will be surprised, for a budget set they are very good. Feel and sound quality is brilliant. You need to remember that plantronics started out in aviation audio, their headsets are used on airforce one and you can tell that some of this heritage is present in the new gamecoms.
I do like the Kaves and the surround sound is arguably a little better on them but the 780 is a great alternative given your circumstances.
Hope that helps![]()
Thanks mate, guess I'll be getting them then.![]()
