Hunter wheel alignment prices
Capt Doufos,
You want to get a fast road setup for yours, not just the stock setting. Here is the fast road setup that WIM did for me.
While I think getting everything straight and true is an excellent idea and something I do at least once a year I question how much 'tweaking' will benefit people in 'normal' road cars unless you are tracking it or it's built to be adjusted fully, which most production cars aren't. Great idea getting it 'sorted' but many of these systems are only as good as the people using them. I have seen alignments done at one place, checked at another and being quite different. Buy with caution is my advice and aim for someone like Centre of mavity or other well respected set up specialists if you are going to get it done, and expect to pay more for it. My GT3 took 6 hours to do as an example...
Exactly, worth paying more to get it right the first time, mine was at center mavity for 8 hours, had seized camber/castor and toe on drivers side though to fix :P
Yep, you really do want to goto Wheels In Motion with you having an mx5. He knows a lot about the mx5 suspension and he will set you up with what you want.
As someone who has used Centre mavity and Wheels in Motion I would say Tony at Wheels in motion every day of the week. With an MX5... its a total no brainer
Chris at Centre mavity sorted my MK5 Golf GTi and my friend's MX5 and both of us have never been happier with the handling of our cars. Chris is very talented and has great insight in everything to do with suspension. Cant recommend him enough.
The machines are good but it makes no difference if the guy using it is incompetent.
I just had mine done at a local place, and they declared that they couldn't do anything with the rear left camber as the nut was on too tight and they might damage it, having just tried to undo it with a 12 sided socket.
I only have 34000km on the car and 28000km of those were in Japan. It hasn't rusted under there at all, god help them if they ever have to do a car with some actual rust on it.
End result is my car now handles worse than when I took it there. At least when it went in the camber was equal all around.
Going to look into some lowering springs which should bring the camber closer to vertical anyway, and then get it aligned somewhere that actually knows what they are doing.
Have a look on driftworks, I think they sell upper arms to alter the camber on the Ceffiro. It look like you are running negative camber already and lowering it will make it worse
The suspension on the 4WD Cefiro is different to the RWD version (It's the same as the Skyline GTS4 and GTR) so Driftworks probably wont help, I've also been advised against the driftworks one anyway, or at least if I use it then once it's aligned to weld the lock nut in place before it comes undone.
Edit: Since the camber is just about in spec, and negative camber isn't bad, per se, should I just get some bushed rear adjustable toe arms (apparently S13 ones fit) and have them set that rear right camber back to around -1°30'
I should probably also get a caster adjuster kit too? or is it not worth the effort?
Edit2: Full figures:
Code:
     Left       Front      Right    |
Actual|Before|        |Actual|Before|  Specified Range
-1°34'|[b]-1°40'[/b]| Camber |-1°24'|-1°16'|  -1°40' - -0°10'
 [b]1°41'[/b]| [b]1°40'[/b]| Caster | [b]2°31'[/b]| [b]2°31'[/b]|   2°50' -  4°20'
 0°04'|[b]-0°07'[/b]|   Toe  | 0°02'|[b]-0°05'[/b]|   0°00' -  0°05'
                Rear
-1°31'|-1°39'| Camber |-0°58'|-1°23'|  -1°40' - -0°10'
 [b]0°23'[/b]| [b]0°25'[/b]|   Toe  | [b]0°25'[/b]| [b]0°18'[/b]|   0°00' -  0°11'
Capt Doufos,
They do really seem to know their stuff, nothing but praise for them all over the net. Will have to find an excuse to go that way.
