- 11 Nov 2011
- Leicestershire
Hi,
Setup is MSI B350 Tomahawk and Corsair H110i.
Upon first boot it was sat at 55c in the bios, I thought it may be a buggy BIOS. But I booted into Windows (on my old install) and saw it was now at 60c in the AMD Ryzen utlity.
Remounted the H110i twice with new paste, no luck, identical temps. Putting it under load was impossible as it hit 70c+ pretty much instantly. It was also very loud.
At this point I really am scratching my head wondering how the H110i could be faulty, wondered if the pump wasn't working etc. I was thinking maybe I could have mounted it wrong, but it really is very very simple to install on the AM4 socket. I saw other people with the B350 Tomahawk reporting normal temps, so I ruled that out.
So I picked up a Ryzen 1700 with the stock cooler.
Firstly I fitted the stock cooler with the 1700x... 62c to 69c at idle! at this point I knew it had to be the CPU.
Fitted the 1700 with the H110i, 31c idle...
So yeah I am RMA'ing the CPU. I have built 100's if not 1000's of PC's and I've never had a faulty CPU. Has anyone else had a faulty Ryzen CPU?
Hope this helps if anyone else has the same issue with stupidly high temps!
