25 Aug 2019 at 00:07 #1 LeMson LeMson Soldato Joined 21 Mar 2012 Posts 4,346 Found an old floppy disk but the sliding thing won't move, it's very bendy too, doesn't feel very ridged. Is there any way to restore it? Thanks
25 Aug 2019 at 00:08 #2 Spit Spit Permabanned Joined 8 Nov 2003 Posts 6,743 Location Yorkshire Try it in a slot?
25 Aug 2019 at 00:10 #3 something daft already!! something daft already!! Soldato Joined 11 Jan 2007 Posts 8,858 Location *̡̡ı ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡
25 Aug 2019 at 01:14 #4 mrk mrk Man of Honour Joined 18 Oct 2002 Posts 106,211 Location South Coast Whatever you do, don't copy it.
25 Aug 2019 at 01:31 #5 LeMson LeMson Soldato OP Joined 21 Mar 2012 Posts 4,346 Spit said: Try it in a slot? Click to expand... Needs to be hard before I put it in a slot, it's floppy in my hand, don't want it floppy in the slot
25 Aug 2019 at 02:16 #6 Flibster Flibster Man of Honour Joined 18 Oct 2002 Posts 43,622 Is it a majestic 8" or a pathetic little 2" floppy?
25 Aug 2019 at 03:47 #7 Vexr Vexr Associate Joined 15 Oct 2018 Posts 1,568 mrk said: Whatever you do, don't copy it. Click to expand... I stand educated at long last.
25 Aug 2019 at 04:02 #8 NVP NVP Soldato Joined 6 Sep 2007 Posts 12,807 Flibster said: Is it a majestic 8" or a pathetic little 2" floppy? Click to expand... 5 ¹/⁴ avg.
25 Aug 2019 at 08:09 #9 LeMson LeMson Soldato OP Joined 21 Mar 2012 Posts 4,346 Flibster said: Is it a majestic 8" or a pathetic little 2" floppy? Click to expand... Definitely a small one, will measure with tape measure later
25 Aug 2019 at 08:36 #10 Terminal_Boy Terminal_Boy Soldato Joined 13 Apr 2013 Posts 13,925 Location La France Flibster said: Is it a majestic 8" or a pathetic little 2" floppy? Click to expand... Go large or go home!
25 Aug 2019 at 09:16 #11 lunar lunar Associate Joined 18 Jul 2015 Posts 440 Location London Had me disturbed when I read the title; only to discover that the discussion was about disks.
25 Aug 2019 at 10:14 #12 Delvis Delvis Caporegime Joined 7 Nov 2004 Posts 30,204 Location Buckinghamshire LeMson said: Definitely a small one, will measure with tape measure later Click to expand... It's just a spring usually. Fix the spring
25 Aug 2019 at 10:20 #13 MartinPrince MartinPrince Soldato Joined 14 Aug 2018 Posts 3,669 Get it fixed before putting it in the slot, pulling out under those conditions might prove difficult.
25 Aug 2019 at 10:38 #14 LeMson LeMson Soldato OP Joined 21 Mar 2012 Posts 4,346 I've been thinking a lot about slots, I think I will ask my friend if I can put it in his slot, I'm sure it doesn't get much use so he should let me. I'm still worried it's not hard enough to go in his slot though.
25 Aug 2019 at 10:41 #15 Deleted member 77746 Deleted member 77746 Permabanned Joined 9 Aug 2008 Posts 35,725 Nothing worse than a party sausage.
25 Aug 2019 at 10:43 #16 Flubble Flubble Associate Joined 8 Mar 2006 Posts 1,411 Location Somewhere, UK will it still work if you take the slidey bit off
25 Aug 2019 at 11:01 #17 paradigm paradigm Caporegime Joined 26 Aug 2003 Posts 37,514 Location Leafy Cheshire Flubble said: will it still work if you take the slidey bit off Click to expand... Yes, but then you are more at risk without the protection.
25 Aug 2019 at 11:17 #18 glenimp617 glenimp617 Soldato Joined 30 Sep 2005 Posts 16,892 NVP said: 5 ¹/⁴ avg. Click to expand... Thank god I'm not the only one
25 Aug 2019 at 11:35 #19 darael darael Soldato Joined 10 Jul 2010 Posts 7,353 The OP should invest in some spinning rust.
