Hello! So, I have set myself the task of Overclocking my CPU today. Its a AMD Phenom ii X6 1045t running at 2.7GHZ. I have played around and managed to get it to 3.38GHZ. After a lot of googling I toned down the NB to 2080mhz and the HT to 2080mhz (I read its best to keep these low).
However, I noticed the Max TDP on CPUZ said 93W, but on Core Temp it said 123w. I don't really understand what TDP means. Is it a case of the power goes up, heat follows but as long as I can keep the temps down its ok? After running Prime 95 for 30 minutes the temps were at 35.C
Am I even doing this correctly? I have an Asus M5A78L Mobo.
I am also worried that If I push the CPU to far, I might destroy my lovely new GTX 670.
Some of you are probably reading this and laughing at how much of a balls up I'm making but any help, anything at all and I would be very grateful!
