Zip said:What would u put them on? These are designed for muscle cars![]()
Wow, I went to have a look and you're right, they really are horrible though. Re the white car is that the one that ended up in light green with castrol decals and stripes? If so I still think it looks rancid.penski said:The arches do belong with the car - the HS came from the factory with that bumper and the arches are works Group 4-spec. Much like mkII Escorts and tarmac/forest arches.
The pic of the white car was taken towards the start of the build project...It finished up looking very nice indeed.
*n
Jonny69 said:Post us some pics of whatever boyed up shopping cart/rice burner you drive then Walliam...
Jagen said:Wow, I went to have a look and you're right, they really are horrible though. Re the white car is that the one that ended up in light green with castrol decals and stripes? If so I still think it looks rancid.
And the escort forest arches look a lot smoother on the body than those do.
You might as well go for the HSR arches and bumper, not nice, but better.
That is a shopping cart. And above all it's a Lada or whatever under it's shiny VW paintWalliam said:I drive a 2003 1.8T VW Bora. So it's none of what you suggested, is it foo.
