No, all emergency numbers aren't covered by a block.
If in doubt, use *341# which blocks all calls except emergency numbers.
I'm talking about cutting the wires.
Unplug the phone... Take it away, throw it in the bin!
no we don't tried it before she went and bought a new phone!moving out it the best idea
You can dial a code in to the phone to block a certain number, all numbers expect emergency and freephone, or just block all outgoing numbers.
http://www.slough.info/slough/s02/s02bt2.html
e.g. dialling *261# will block all outgoing calls (maybe incoming, not sure)
lmao does this number actually work? Is it free? Is it BT only?
Do you pay BT for your line rental?
Thanks I'll give it a try and I'm in Hull can't get BT unfortunately.
