I've been making up excuses to replace my 2600K which still seems to blast through everything.
My 2500k is still great 5 years on. They must have been some of the best chips ever made.
So it's nearly as good whilst being nearly as expensive...5 years later.Anandtech posted an interesting article comparing an i7-2600K (OCed) to a new Kabylake i3-7350K here -
The Intel Core i3-7350K (60W) Review: Almost a Core i7-2600K
So it's nearly as good whilst being nearly as expensive...5 years later.![]()
HeX;30470312 said:Once again a performance article doesn't show minimum FPS.
Psycho Sonny;30483681 said:I have a 2500K @ stock (overclocking has never been my thing) what CPU uses the same socket and would be worth buying now second hand? is there any?
Sampsy;30467061 said:I asked a similar question to your title on the LTT forums but didn't get much of a response. While the body of your OP is referring more to how long will the 2500k be useful (which is discussed endlessly) I'm actually curious how long my little chip will last before it fries itself.
My 2500k has been running at 4.8/5.0 Ghz (with speedstep) pretty much continuously since 2011. That's just been using a H60 - not a bad cooler by any means but it's no custom loop. Think temps of 60-80 degrees while gaming and 30-40 at idle along with 1.448v at load.
I'm constantly reading how higher temps and volts will reduce the lifespan of a CPU and so many people put a lot of effort into lowering temps by a few degrees and volts by a few mv. But nobody seems to have a clue how much higher temps and voltage typically reduce CPU lifespan. As far as I can tell nobody has conducted a long-term study. My anecdotal evidence seems to suggest it makes far less of a difference than people think it does.
