- 23 Dec 2014
so installed the new cpu cooler and getting much better temps. Idle 24 and prime 95 15 mins 54. Must have been the poor screws that my old cooler had. Thanks for everyones input
Just up the multiplier, you'll do 4ghz on stock voltage I reckon, in fact I think mine ran 4ghz with a voltage drop...
Beware results from other people regarding temps etc, fan speeds and coolers vary massively. I'm at 4.5ghz as psidetracked is but I see 65-70 degrees when gaming and that is on a Dark Rock Pro 3 which is a decent piece better than an hyper 212, mainly because I have it set to run at min fan speeds right up to about 75 degrees as noise performance is of higher priority to me.
Think i will leave it for now. My games all hit good fps anyway now so no need. Does say 4.4 ghz vs 3.8 make a big fps difference when gaming ?
I stand corrected. Even so, prime is not a good indication of everyday temps as nothing will heat a cpu up that much in normal use.
