I'd wait for Ryzen but if more cores matters than just core speed there's always ES version of the Xeon's available.
I will say you will have no issues with Ryzen causing incompatibility with software. Hardware wise, well depending on what you are doing with regards to building a system will really depend on that .
If it's mission critical and not just for leisure or gaming definitely let the dust settle and see if there are any major issues. .
I agree, there is no way its worth anything like the price it is, way to expensive.The 6900K in general is a rip off, .
Yes, I need the PC for work. I would have thought it would need 1 year testing, as you say let the dust settle.
You can't say that with certainty though. AMD can't test every version of software / hardware combination. The DDR4 ram might not be on the validated list.
When it's released the best testers will get to work and any issues will be quickly identified.
If we did we would not be ordering such machines.
I would say that unless you are using some very old or oddball software you will be fine. I am happy to stand behind that statement.
I have never seen any cpu fail to work with any programs no matter how new it is. Ryzen will be fully complaint with windows and the x86/64 architecture.
Hopefully Ryzen will shake up Intel's crazy pricing a fair bit
Once Ryzen has been out a week or two you should be able to pick up some pretty cheap 6900K's
Either that, or Intel X99 sales will fall off a cliff.
https://www.youtube.com/watch?v=tj5E8tKLO2Q
10-core Skylake-X for £600? We can dream
Yeh I know, but for some reason the Op wants a 6900k.The overall Ryzen package will still be faster and cheaper. I can't see X99 being cheaper than the Ryzen top-end motherboards.
Yeh I know, but for some reason the Op wants a 6900k..
