- 11 Aug 2003
- Taunton, Somerset
Hi all,
Hoping there is some one out in OCUK land that can help me get my i7-920 to 4GHz
The CPU is a D0 revision and I bought the whole system about 2½ years ago. I have been running it at 3.8GHz its entire life
as I've been wary of temperatures! So now I've grown a pair I've decided I want 4GHz
i7-920 D0
Gigabyte GA-EX58-UD5
Patriot Viper 1600MHz
Corsair H50
Be-Quiet 900w PSU
I was running on F7 BIOS but I have now flashed it to F12
I have been following this guide - the quick and dirty settings wouldn't work
When the multiplier is set to 21 I am getting a stock vid between 1.232 and 1.248 running prime 95. I have used the
following settings in th BIOS
Advanced CPU Features:
CPU Clock Ratio ................................ [21x]
Intel(R) Turbo Boost Tech .................. [Disabled]
CPU Cores Enabled ............................ [All]
CPU Multi Threading .......................... [Enabled]
CPU Enhanced Halt (C1E) ................... [Disabled]
C3/C6/C7 State Support .................... [Disabled]
CPU Thermal Monitor ......................... [Enabled]
CPU EIST Function ............................ [Disabled]
Virtualization Technology ................... [Enabled]
Bi-Directional PROCHOT ..................... [Enabled]
Uncore & QPI Features:
QPI Link Speed .............................. x36
Uncore Frequency .......................... x16
Isonchronous Frequency ..................[Enabled]
Standard Clock Control:
Base Clock (BCLK) Control ................ [Enabled]
BCLK Frequency (MHz) .....................133
PCI Express Frequency (MHz) ........... [100]
C.I.A.2 [Disabled]
Advanced Clock Control:
CPU Clock Drive ..............................[700mV]
PCI Express Clock Drive ................... [700mV]
CPU Clock Skew ............................. [0ps]
IOH Clock Skew ............................. [0ps]
Advanced DRAM Features:
Performance Enhance ...................... [Standard]
Extreme Memory Profile (X.M.P) ......... [Disabled]
System Memory Multiplier (SPD) ........ [8]
DRAM Timing Selectable (SPD) .......... [Quick]
Channel A + B + C
Channel A Timing Settings:
##Channel A Standard Timing Control##
CAS Latency Time ......................8
tRCD .......................................8
tRP .........................................8
tRAS .......................................24
##Channel A Advanced Timing Control##
tRC ........................................ [auto]
tRRD ....................................... [auto]
tWTR ...................................... [auto]
tWR ........................................ [auto]
tWTP ....................................... [auto]
tWL ........................................ [auto]
tRFC ....................................... [auto]
tRTP ....................................... [auto]
tFAW ...................................... [auto]
Command Rate (CMD) ................ [auto]
##Channel A Misc Timing Control##
Round Trip Latency ...................
B2B CAS Delay ..........................
Advanced Voltage Control:
CPU
Load Line Calibration ................. [Enabled]
Dynamic Vcore (DVID) ............... [Normal]
CPU Vcore ............................... 1.26875v
QPI/VTT Voltage 1.150v ............1.255v
CPU PLL 1.800v ....................... [auto]
MCH/ICH
PCIE 1.500v ........................... [auto]
QPI PLL 1.100v ....................... [auto]
IOH Core 1.100v ..................... [auto]
ICH I/O 1.500v ....................... [auto]
ICH Core 1.1v ........................ [auto]
DRAM
DRAM Voltage 1.500v .............. 1.66v
DRAM Termination 0.750v [AUTO]
Ch-A Data VRef. 0.750v [AUTO]
Ch-B Data VRef. 0.750v [AUTO]
Ch-C Data VRef. 0.750v [AUTO]
Ch-A Address VRef. 0.750v [AUTO]
Ch-B Address VRef. 0.750v [AUTO]
Ch-C Address VRef. 0.750v [AUTO]
I can up the BLK up to 178 and the system remains 24Hr stable. At 180 it fails.
I thought I had the system stable at 3.9GHz (Blk 186) as it passed 18Hrs of prime 95, but trying the same settings again it has just failed ( 1.29375 vcore)
Not sure what to do as I have tried lots of different QPI and vcore combinations an just can not seem to get the chip to run quicker
i7-920 D0
Corsair H50
Be-Quiet 900w PSU
C.I.A.2 [Disabled]
Channel A + B + C
CPU
MCH/ICH
DRAM
