OK Something strange is happening....For some reason, lets call it divine inspiration!!
I decided that with the new memory settings (9-9-9-24) and 1.7 pll I hadn't had the QPI on lower settings so My new settings are as follows
Advanced CPU Features:
CPU Clock Ratio ................................ [21x]
Intel(R) Turbo Boost Tech .................. [Disabled]
CPU Cores Enabled ............................ [All]
CPU Multi Threading .......................... [Enabled]
CPU Enhanced Halt (C1E) ................... [Disabled]
C3/C6/C7 State Support .................... [Disabled]
CPU Thermal Monitor ......................... [Disabled]
CPU EIST Function ............................ [Disabled]
Virtualization Technology ................... [Enabled]
Bi-Directional PROCHOT ..................... [Enabled]
Uncore & QPI Features:
QPI Link Speed .............................. x36
Uncore Frequency .......................... x16
Isonchronous Frequency ..................[Enabled]
Standard Clock Control:
Base Clock (BCLK) Control ................ [Enabled]
BCLK Frequency (MHz) .....................191
PCI Express Frequency (MHz) ........... [100]
C.I.A.2 [Disabled]
Advanced Clock Control:
CPU Clock Drive ..............................[900mV]
PCI Express Clock Drive ................... [800mV]
CPU Clock Skew ............................. [0ps]
IOH Clock Skew ............................. [0ps]
Advanced DRAM Features:
Performance Enhance ...................... [Standard]
Extreme Memory Profile (X.M.P) ......... [Disabled]
System Memory Multiplier (SPD) ........ [8]
DRAM Timing Selectable (SPD) .......... [Quick]
Channel A + B + C
Channel A Timing Settings:
##Channel A Standard Timing Control##
CAS Latency Time ......................9
tRCD .......................................9
tRP .........................................9
tRAS .......................................24
##Channel A Advanced Timing Control##
tRC ........................................ [auto]
tRRD ....................................... [auto]
tWTR ...................................... [auto]
tWR ........................................ [auto]
tWTP ....................................... [auto]
tWL ........................................ [auto]
tRFC ....................................... [auto]
tRTP ....................................... [auto]
tFAW ...................................... [auto]
Command Rate (CMD) ................ [auto]
##Channel A Misc Timing Control##
Round Trip Latency ...................
B2B CAS Delay ..........................
Advanced Voltage Control:
CPU
Load Line Calibration ................. [Enabled]
Dynamic Vcore (DVID) ............... [Normal]
CPU Vcore ............................... 1.375v
QPI/VTT Voltage 1.150v ............1.315v
CPU PLL 1.800v ....................... 1.7v
MCH/ICH
PCIE 1.500v ........................... [auto]
QPI PLL 1.100v ....................... [auto]
IOH Core 1.100v ..................... [auto]
ICH I/O 1.500v ....................... [auto]
ICH Core 1.1v ........................ [auto]
DRAM
DRAM Voltage 1.500v .............. 1.66v
DRAM Termination 0.750v [AUTO]
Ch-A Data VRef. 0.750v [AUTO]
Ch-B Data VRef. 0.750v [AUTO]
Ch-C Data VRef. 0.750v [AUTO]
Ch-A Address VRef. 0.750v [AUTO]
Ch-B Address VRef. 0.750v [AUTO]
Ch-C Address VRef. 0.750v [AUTO]
Wit the above settings I am now 4 hrs and 20 min stable and counting!! I will up date when either it fails or this evening if it is still going. Temps are at 83ºc peak (2 hrs ago)
