Caporegime
Those settings look grand, 1149 is ok, if you want your ram to run higher youll have to up the bclk to 200 x 20 (4ghz), at this setting with a x 6 ram multi your ram will run at 1200mhz, 6 x 200 bclk = 1200mhz ddr. As you raise/lower the bclk, the ram speed rises/drops in line.
21 x 191 would give you 4ghz as well, but your ram would run at 1146.
The next ram multiplier is the 8x, however this would have your memory overclocked quite a bit above it's rated 1333mhz speed, not sure if your ram would clock that high.
