i7 920 overclocking settings
Gaming and general use won't ever reach those temps, so yeh you could stick with the settings i guess, but most wouldn't be happy to, its all personal choice really.
The only thing that would happen is it would over heat, and then it would throttle down the speed to get things running cooler again, its a safety feature.
Coolers that i would reccomend are The first 2 require u to use your own fans, or buy some at the same time.
The below coolers will easily take those temps down to sub 80, maybe even 70, really all depends on case airflow also.
Prolimatech Megahalems Rev B
Thermalright Venomous X
Cogage Arrow
Thermalright Silver Arrow
Noctua DH-14
So therefore you could use the same settings, as they are now, and everything should be fine, if you never reach prime type load lvls.
Bare in mind, it is entirely your choice, we can only advise as such, i would still say a new cooler would be best though, but only if you can afford it, if not, then just keep an eye on the temps at times.
thanks pal, I hear you hear loud and clear
for now I will stick with the temps, keep them monitored regularly especially if gaming / video editing etc and then make a decision whether to purchase a new cooler...
do you know of any good "gadgets for win 7 desktop" that will enable me to monitor temps easily instead of having to open "coretemp" every time?
thanks for all your help, I owe you a big drink
