Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
Simply put, I want to get an ice cream machine. There is always ice cream in my freezer, whether it is vienetta, cornetto, Ben & Jerry's Haagen daz etc. So I thought why not try it myself. All it seems it takes is getting the base right, and then experiment to the max for some funky results.
What particularly interest me is making my own frozen yogurt...can't for the life of me find anything other than Cherry Garcia! and at £4 a tub it isn't cheap.
So after doing some research, it seems the machine with a built in compressor are the best bet. Mainly for 2 reasons.
1 - No need to chill the bowl a day or over night before hand. So if i want to make ice cream on impulse, i can.
2 - I saw some youtube vide, the "bowl" for the machine i wanted to get are WAY huge, it doesn't look like it will fit in my freezer, not without taking some food out.
With the 2 above, the lack of planning (i am too impulsive when it comes to food) and can't keep the bowl in the freezer all the time it means i will seldom use it.
Which leaves the option of getting one of those with a built in compressor which after some research....this one.
Gaggia Ice cream maker
It is a little pricey (though it is the same price as my Gaggia espresso machine), but for a life time of fresh ice cream?
Anyone got an ice cream machine? whether a bowl one or a compressor one? If you got a bowl one, did you wish you got one with a compressor or vice versa?
