ICS help
we've changed the ip of the router to 192.168.1.1 so to access the web based config goto start, run and type http://192.168.1.1 enter username/password...
<SNIP>
This is what UPNP is for.... You don't need to touch anything on the router side. I have configured a lot of xbox 360s using ICS. Theres no problem with the setup I put above.
i took over from the stuff above. He's bound to get trouble when the first thing ICS is gonna do is assign his NIC 192.168.0.1 (the same as his router) He's obviously not the most experienced with networking devices. Its not ideal but a bit of ****** ICS DHCP might simplify the matter.
good luck with the setup anyway Cemetery. i'll leave it to Mr Pedantic above.
is that for me?
i assume not with the edit. oh and thanks for replying to my other sbs topic. which is around a year old, superb!
erm, you need to add 3 rules,
Had only done 2 :rolleyes: putting one as UDP/TCP Doh.
Having changed that around I tried again & it finally connected & detcected an update \0/ it then disconnected a couple of times but it just downloaded it so I think I am up & running. In fact yes I am :D
Cheers for the help all in this thread especially $c8t@ (who may wanna edit his last couple of posts to remove the partial swearing before the don's get the ban hammer out).
