IDE to SATA problems
28 Nov 2005
hi guys after recently upgrading my computer this new mobo has no ide slots on it which is kinda annoying so i picked up a IDE to SATA converter on ebay,
my problem is i cannot get windows to see the drives the mobo is asus P8Z68-V
ive tried ide mode in bios but nothing seems to work , is there a specific way to get these working.?
thanks.
Are you sure you've got the right type - I'd have expected an IDE to SATA converter to allow you to use a SATA drive on an IDE port. If it is the right type, have you tried it with one drive at a time as master or slave?
I tried a bi-directional one a while ago and had nothing but trouble with it. Your best bet might be to get a cheap pci controller card.
Those converters are rubbish - I've had to bin a couple of them.
It seems like they only work with older chipsets which defeats the purpose. As suggested PCI controller card for a fiver FTW
I Have a sata to IDE adapter in my PC and it works fine.
Are you sure you have power going to it? should be a small black cable powered by molex.
Are you sure the switch is set the right direction?
thanks for the replys , yeah ive tried the connector both ways , i got it to detect the drive when booting to desktop but it didnt appear in my computer?
can you recommend a controller card all the ones on ebay say not compatible with w7.
If you haven't already:
Click start
Right click on Computer
Click manage
Click Disk Management
Right click the shaded areas that represents the HDD and create a new simple volume and assign a drive letter
