Also watching this with interest. Was interested in the Ikea Markus but maybe I should spend it elsewhere.
Don't get me wrong, it's not too bad for the money, but I think better chairs are out there, especially when we're using them so heavily... when I bought mine, I only intended to use it for a few hours a week, but now, it's 8 hours a day.
I also don't think they're as good value as they used to be; my Mrs got one very similar to it from another well-known furniture/home supplier that rhymes with Mayfair and it was less than half the price that they're charging now, and is just as good as far as I can tell.
Still on the fence with this. I’ve asked the question elsewhere and most seem to suggest gaming seats are ‘junk’. I’m not going to go that far though, and plenty of places seem to suggest that actually they are still comfortable and ergonomic as gamers themselves will be glued to a desk for hours on end, which makes sense. I personally like the look of the gaming seats better.
There’s also a few people who’ve told me these second hand office/task chairs can be varying degrees of worn out/knackered, and a few grumblings about the build quality of some Steelcase seats, and quite a few who suggest the HM ones are good but somewhat overrated for comfort.
Also as said, it’s not exactly practical to try them out and I only have another 3 weeks to buy one before the offer of free money runs out.
I think it might be helpful to narrow down by design. Do you want a mesh like design like HM employs or a firmer/less mouldy design like gamer chairs/some steelcase options?
I think my priorities are something that will do well for working which will be 90% of its use, but also something nice to chill out in when the need arises. In theory the mesh ones are cooler, however the others look better, I’m pretty open minded really. And, if buying second hand, something that won’t break after 13 months.
The noblechairs one is definitely one on my list. In particular I quite like the look of this one...
