Yep... it's called... die of head exploding from looking for 2 and half months at monitors yet getting 2 crappy ones and sending them back only to be left with nothing. That's actually the name of the illness I am currently suffering with.
Basically. I play games, quite regular. I don't buy tons of games but I like to play my current games longer, so based on the fact that I don't buy 20 games a month, doesn't mean I can put up with OK-ish quality. I have a good eye, an I notice things easily. Likewise, I watch blu-rays on my PS3, and I also play games on my PC. This is cause for problems, as I need a good all rounder but can't afford to spend more than £210 - not only that of course but £210 will only end up buying you the worst quality chinese tv tech imagineable.
A few weeks back I got a Samsung Syncmaster XL2370HD (one of the same, two naff-o monitors, because they turn themselves on when they feel). It fit my criteria nicely. It had great imagery. Good response. No ghosting. Great colour reproduction. Practically no input lag and speakers... which meant the PS3 could have the internal good quality speakers (bass distortion on GT5 at level Vol. 21+ tho), whilst the PC could have the Logitech X-230s. Sadly, the screen turned itself on multiple times throughout the night trying to connect to DVI - when my PC was off. In the end, I had to unplug the monitor just to get sleep. I asked Samsung about it and they said it was a fault so I contacted the buyer and had it sent back. I had a replacement shipped (same TV/Monitor), an this one, though having more responsive touch panel buttons, suffered the same problem - not to mention the slightest tap on the desk resulted in about 10 seconds of nasty plasticy squeaking.
It really is a shame that that monitor ended up that way, an I find it hard to believe that 2 monitors, with different serial numbers (though shipped in the same box, quite odd), would come to me with identical issues, with Samsung's lousey non-English speaking support claiming they were faults. I think their quality has slipped. My current Samsung Syncmaster 2032MW 1680x1050 which I am using now is about 4 years old and is still going well, but is a problem because it suffers with some input lag, doesn't have 1080p and is rather dim and colour inaccurate. Not suitable for my all round, gaming - movie - web surfing needs. It performs dreadfully on Black Ops for PS3.
Each time I search the nets/reviews/comparisons, I keep ending up with the XL2370HD sitting in front of me. It's like... "THIS SCREEN IS THE BEST OUT OF EVERYTHING, FOR WHAT YOU NEED", but it appears to me that the squeaky base and magical voodoo screen which turns itself on, are going to be a problem.
Does anyone have a suggestion for a 22"-27" screen with decent (3W+ internal speakers, no distortion preferably), with 1xDVI and 1xHDMI at minimum, with good colour reproduction, good image quality, no ghosting, pretty much no input lag? LOL... sounds laughable doesn't it? Maybe the XL2370HD is the best? Seems like I'm asking a lot for my money, which is undoubtedly true.
I'm not at all pleased at these manufacturers for side-stepping those who need a one screen solution for multiple things. I'm in a medium sized room, an having a 20" monitor and 32" tv side by side, is completely absurd due to heat production. Take into account my room is where the afternoon/evening sun shines an that no air flow ever about 95% of the year blows in through my window. Regardless of whichever doors or windows are open, heat never escapes. CCFL doesn't help either. Unless of course anyone has the knowledge or can steal me a 32" TV with good colour, response, no ghosting, no input lag, good speakers etc, then otherwise I'm screwed right?
Black Ops looks so awful on PS3 with my 2032MW. Upscaling on this monitor is so bad it makes you vomit uncontrolably. The black are... not black... unless you turn the brightness down more, so everything is uncomfortable and dim.
HELP! Seriouesly. I've been talking in this thread : http://forums.overclockers.co.uk/showthread.php?t=18248437 - with PCM2 for ages and I'm getting no where.
Should I just put up with the XL2370HD? Buttons don't work, wakes me up in the middle of the night? Has speaker distortion on GT5 at any volume level above 20?
Yes/No?
I'm being totally serious by the way.
Thanks for any help.
Peace
Yes/No?
Peace
. I can assure you, I am calm, lol, don't let my over-exaggerated post fool you.
