Images of items I have purchased (except trainers)
26 Jan 2006
Belfast
Yeah they have a good sound, and although I agree they hurt the ear if you dont position them right, most of the time they are comfy.
Only issue I have is that I've had to change music apps as Poweramp keeps popping/cracking during playback. The other app(s) I use dont :confused:
Not had an issue with that, though knew there where syncing issues with Youtube etc, but I was never going to use it for that. Have you ran all the updates? The app isnt good an notifying you if there is one.
23 Sep 2007
Essex
I did an update yesterday. Ill see if there is another. Thanks !!
28 Apr 2011
Barnet, London
Ticwatch any good?
Any good deals on smartwatchws for circa £200 or worth waiting for the next generation?
Yeah, seems nice. I would have it over the TicWatch Pro, but I think I'll be sticking with the Skagen Falster 2 as I prefer the smaller, lighter design.
Does the next generation have the Qualcomm 3100? I'm told the only difference is the low power chipset added which means you get better battery life. 99% of the time mine goes on charge overnight so it doesn't really bother me, I don't go below 50% battery...
13 Jul 2009
Llanelli
Here's something no one apart from me has ever bought.
A custom made cable for a specialist application. Bought 50 of the little blighters for £21 each.
Bought for work, not specifically for me, but does save me having to hand build them.
And a USB 3 PCI-E card. (not the best photo)
Still running a pre-USB 3 system and have had enough of rubbish USB transfer speeds and the poor USB voltage on my computer.
