I actually have the same board as you lol, Im having a bad time with it though... All stability programs are saying that im stable. I have been running prime95 torture test for over 8 hours all came back fine, even blend. linx, intel burn test. But i keep getting BSOD code 124 at random times while browsing web or on idle. No idea why and i cant cure it!
1.5V seems to seriously degrade the chip in a matter of weeks if early reports are to be believed.
Well the ASUS tech guy just did 5.2Ghz i7 2600K Overclock on ASUS Maximus IV Extreme P67 1155 from here
http://www.youtube.com/watch?v=lajZi-JAFXA
why would he do it if it would brake the cpu I was going to buy this and do this but know I may wait and see not sure why he did it if its degrade the chip![]()
will 4.6 kill your cpu? As I think the Overclock on ASUS Maximus IV Extreme has a pre configured 4.6 somewhere in the bios
Do you have a MSI P67A C45? I do and get the same problems its soo annoying as I can't overclock as far as the chip allows.
what vcssa? not to sound stupid
wow i am out of the computer scene but base clock of 100? is that not a bit pants?
back in the day it was always better to push that as far as you could before upping the multiplier.
glad i read this thread before trying to overclock! i take it the way the chips run is different these days? or is base clock not what i am thinking of?
cheers
ps what is the fastest i can safely hope to aim for on a stock cooler, at stock voltages?
am not gonna upgrade my cooler until i stick a new board in.
The BCLK can't be touched as it's the clock on the ring bus, so will OC SATA, PCIEX and all sorts of stuff you don't want to clock, but clocking the multiplier is as easy as pressing a button.
Imo, on stock cooling 4.2-4.3ghz should easily be attainable with lowish temps and vcore around 1.2v
