Edit: Double post whoops
Edit 2: Well I pretty much know the answer to my question above, anything over 1.4v is really not considered safe for this CPU - I will try manual settings tonight and try achieve 5GHz around 1.4 - 1.45v
Edit 3: Made some progress at lunchtime, set manual voltage to 1.465 with LLC settings @ extreme, it peaks at 1.502v & 63 degrees after 5 mins of Prime95 (i'ts all I had time to do!). I tried turning down the LLC after this but couldn't get it to boot into windows. Do we think 1.502v peak might be ok for 6-12 months? Bearing in mind if I do kill it I will just buy a Haswell! (Though ideally I would like this one to last until the 20nm chips come out).
