Right through testing on this board and DVID it's pretty much unusable!
You can't use Load Line while using Dynamic Core manually(wont let you) and also you have to have CPU CORE volts set to Manual otherwise DC is stuck on AUTO and you can't use it.
If use volts via Dynamic Core it can drop VERY low when running prime and intel burn test it went from 1.300v down to 1.171 which means you need Load Line But it wont let you if using DC lol
