If you aren't doing much editing then even a bit over 30Mbit/s is fine at 1440p/60fps - if you are doing a bit of editing through the quality quickly degrades :S
Same problem with the sound capture - its fine if you aren't doing much remixing but if you start processing it a bit and recompressing it quickly drops below ideal.
Well, it was to be expected. I think it does look better than previous ShadowPlay recordings, though whether it's really worth it to me for the long term, I don't know. Once all my stored footage has run out, I'll try using Dxtory for each playthrough and compare.
