could you link me to such drivers?i think the right drivers would solve this problem
No, that was an earnest question, I genuinely didn't have a clue. You passed if what you said is true![]()
can you go to control panel then device manager and check if theres ant yellow question marks around any of your hardware?....the first thing you need to do on a install of windows is install the drivers for the mobo stuff.....which gives you all the chipset ,usb ,pci express etc etc drivers...basically all the most important stuff your pc needs.....if you dont install these first and install say a netgear wireless card chances are it will run like a pile of poo
the only yellow mark is next to 'other devices'
it says unknown device and is not able to find a driver for it.
go to system device in device manager and open it up - there should be something called Intel Management Engine Interface listed there, I suspect that is your yellow icon and you wont be able to find it
does it see your netgear wireless card in there?
put you mobo cd back in and tell it to look in there for drivers on the other device it cant find
put the mobo cd in....right click on the device it doesnt see and choose update software....then point it to look on the mobo cd via browse location
then if its mobo related it will find it...if its not then it may not matter as much anyway
Look in sound,video and game controllers, what do you see there, is there more than 1 item?
nice idea but if the drivers are compressed or in cab files then it won't work![]()
thank guys, i'll try that suggestion in a second.
If all else fails, is a network card an option?
Darn. Ive tried both suggestions. It tells me that the drivers are up to date. then when I try to use the Disc to update the drivers of the 'unknown device' it cannot find any on the disc.
