MNuTz said:if you want the noise of an induction kit you can always buy a second hand filter cover and drill several holes into it, its supposed to make it sound better.
DanB said:Fair enough - just wondering. You may laugh, but it's very nippy 0-30, and with Eagle F1's on it'll go round corners like nothing on earth. I was just wondering if there was a relatively easy way to liberate a little more power.
1CE said:You guys are mean![]()
Drilling holes in the air box will give an induction roar but your going to be sucking in hot air from the engine bay, which will most likely bog down the acceleration.
Mr_Sukebe said:As agaisnt using a cone filter drawing air from?
1CE said:The engine bay..
) but is the science slightly different for diesel engines or would I be better just leaving it with the standard air filter?
