- 25 Nov 2009
This is still technically watercooled but both the GPU's and the CPU use all-in-one solutions
Still 4930k with the same 32Gb RAM @2400MHz and Quad fire 295x2 but this will leave £1200 for you (or others more knowledgeable ) to spec the best monitor setup...
YOUR BASKET
2 x PowerColor AMD Radeon R9 295 X2 8192MB GDDR5 PCI-Express Graphics Card £999.95 (£1,999.90)
1 x Intel 4930K 3.40GHz (Ivybridge-E) Socket LGA2011 Processor - Retail (BX80633I74930K) £429.95
1 x Asus Rampage IV Extreme Intel X79 (Socket 2011) DDR3 Motherboard £309.95
1 x Kingston HyperX Beast 32GB (4x8GB) PC3-19200C11 2400MHz Quad Channel Kit (KHX24C11T3K4/32X) £289.99
1 x SuperFlower Leadex Platinum 1200W Fully Modular "80 Plus Platinum" Power Supply - White £179.99
2 x Samsung 250GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE250BW) £104.99 (£209.98)
1 x Corsair Carbide 540 High Airflow ATX Cube Case - Black (CC-9011030-WW) £98.95
1 x Corsair Hydro H105 Extreme Performance Liquid CPU Cooler (CW-9060016-WW ) £89.99
1 x Microsoft Windows 8.1 64-Bit DVD - OEM (WN7-00614) £74.99
1 x Corsair Fan, SP120 PWM Low Noise High Pressure Fan 4 pin, Dual Pack (CO-9050012-WW) £25.00
1 x BitFenix Alchemy Cable Bundle - Red £21.95
1 x Asus 24x DVD±RW DRW-24F1ST SATA ReWriter - Black (Retail) £17.99
1 x Corsair AF140 Quiet Series Low Noise High Airflow - Single Pack (CO-9050009-WW) £14.99
1 x BitFenix Alchemy 8pin PCI-E extension 45cm - Red £6.98
1 x BitFenix Alchemy 6pin PCI-E extension 45cm - Red £6.49
Total : £3,799.99 (includes shipping : £19.10).
YOUR BASKET
