Insomnia I55 Thermaltake project
It's such a good looking cooler that that's not necessarily a bad thing!
Indeed :)
I prefer to watercool an entire system, but this aircooler fits the theme so well and it looks the business tbh.
What an interesting ssd placement, you crazy dutch guy ! ;) The card looks the dogs, the red fans will go nicely.
HA I might be just a tad odd ;)
Indeed I agree :)
For this project HyperX again showed their support by putting in a set of 4*8GB 1600Mhz DDR3 HyperX BEAST modules. With the nice black PCB they are rocking nowadays. :thumb:
And 3 of their 3K 120GB SSDs. Both fitting the colours of this theme perfectly.
Thank you very much HyperX! :clap: And especially K.J. and E.B. for this amazing set of hardware.
This delivery I received later. The waterblock to use and fittings for 16mm hardline tubing and about 6 meters of Thermaltakes own 16/12 mm PETG tubing.
I am arriving at the point where I can finally start fitting some hardware. :thumb:
Thanks Martin for the emergency package.
Onwards with some more plexi work :)
First off the small window for over the rear SSDs. This is there to protect the SSDs from people that like the ones too much that are fitted to the rear of this project. I tried to somehow keep some lines from the inside involved in this.
I polished up all edges of the window.
Next up another piece of acrylic. This time for the mounting of a single HyperX SSD. I tried to make the shape of the paintjob resemble the X on the SSDs. This will be mounted behind the motherboard tray with a doorwindow so it is always visible.
This is a short video of the new front of the case.
The stock front is black plastic and has a sound dampening layer behind it.
Like I showed in my first update in this log I took the front off and sawed out the sound dampening layer. I replaced the front big panel with a special LED black plexiglass one that changed colour based on the light behind it. I then painted the rear of it black and lasered out the gfx Django drew for me (big thanks like always Django). Then put a clear plexi panel behind it with a pattern lasered into it and a red LED strip around it.
This makes it so that when the PC is turned off the front is just about black. And the gfx only show up when the PC has been turned on.
For those that might see it directly. Yes I have been influenced by the new In INWIN case with the red hex front. The technique behind it is different, but I liked it a lot and I thought it would suit this system a lot. Especially with the TT esports logo and the TT in the bottom end. The front stays clean like this, no opening for fans or grill. But still it looks different :)
edit:
how do I get this video to work????
Thank you very much Faheem!!! +1+1+1+1+1+1
I tried the short one but apparently still did something wrong.
w00000p
And thank you for your kind words as well :)
I made some sleeves for this system. 24 and 8 pin EPS rainbow extensions. For the GPU I redid the stock cables. Had to shorten them considerably. They will run stright up from the PSU to the GPU through the PSU shroud.
Next update. I had made all desired holes for tubing in the PSU shroud so I could paint it. I am very happy with the end result.
wow, so much epic progress made since I last checked in!!
Love the GPU, KFA make some of the best looking cards out. Really like the CPU block too. And the lighting effect, yeah that rocks too. Really nice work mate.
Thank you very much Luggs :)
Very nice to read.
cables go very well with the theme.
Thanks Faheem. I have tried to follow the theme and not make them attracting too much attention.
