I'm fairly sure the voltage is on auto... In short, what's the best way to work out a suitable voltage? Slowly lower it until you see issues? Then back up a tiny bit? But how do you find out where to start from?
Sorry for all the questions, I just went for a simple overclock when I did it by upping the multiplier
Just for info, currently typing this out I'm on 1.320v
Thanks for the tips too, couple more questions if you don't mind haha:
1. With regards to soaking the TIM tube, never done that before, I guess no water gets in if you stand the syringe face down in hot water, just make sure no water gets in the 'top' of the syringe (towards the handle)?
2. What do you mean by going the same direction as the die? I've never heard that term before so I'm not sure what the die is?
Thanks!![]()
i think he means start just above the middle and put the tim in a down stroke manner not across.
