Installing a new hard drive...
2 Oct 2004
N.W London
Hi,
Just installed a new hard drive....
Its being detected in the bios and in system properties but not in "my computer"
What have I overlooked
Please help
P.S. Drive settings are correct etc...I am using it as a second hard drive...
thanks mate :D
Never done that before, I always thought it would become activated if it was detected in the bios etc?
Cheers matey :D
that worked fine for my first hdd
for my second hdd although it detects as I had a partition on it when I go to explore the hdd its asking me if i want to format.....Hell No....
This 2nd hdd also contains windows which I dont want to run becuz I know it had issues I just want to access the data and back it up and then format the entire drive and start again....
How can I access it without having to reformat?
Please help
http://img206.imageshack.us/img206/9428/hdd1eq.png
thats a screenie of what I can see in "disk management"
Now I want to access the drive without partitioning any ideas how?
Its a samsung drive....I believe my jumper settings maybe wrong....
Which would be the jumper settings to set it as a slave? i followed the diagram on the hdd but it only detected 31gb so I took the jumper out altogether and altho it detects the full drive now I dont want to format it as it contains all my info...
Pls help??
The 160g was the original it had a trojan on it so I thought I would format it but before I did I need to back everything up...
So I made a fresh xp installation on the 10g as the 160g would not boot at all etc So I have win xp on the 10g and thought I would connect the 160g and access it....
However as you can see its only seeing 31.5g and says the other 117g is unallocated space...
no worries I have sorted it...
the restore tho is in folders of extensions....i.e. jpgs, docs etc without the file name....
so i have to go through 149g of data deciding what i want and what i dont want
bugger :-(
ALWAYS MAKE BACKUP'S
