Heat sink dimensions: 78x80x43 mm
Fan dimensions: 80x80x25 mm
Rated voltage: 12 V
Air flow: 32.4 CFM
Bearing type: Hydro bearing
Fan speed: ~ 2.600 RPM
Noise level: 20~23 dB
Power consumption: ~1.56 W
Certificates, approvals: CE, FCC
Weight: 305 g
Application: AMD Athlon XP up to 3400+ • AMD Sempron up to 2800+ • AMD Duron up to 1.8 GHz (all socket A)
Are those push-pins?
If they are then you can usually squeeze the back of them with a pair of pliers and push them through the holes.
Nah it should be fine.
If it does happen to touch the Zalman then the Zalmans fins are easy enough to bend/break to make room.
