Did you have any trouble getting the manifold bolts out from the block? Did you take any precautions? (Plusgas, blowtorch etc?)
None at all, they were 12mm and came off quite easily
Fidanza flywheels and Exedy clutches are quite well respected for HondasFlywheels are only available from the states on Ebay though!
looks like fun.
how many miles were on it when you started the rebuild? did you test the compression at all before hand?
None at all, they were 12mm and came off quite easily![]()
I bet I have uber problems with mine
Also the so called "bitch pin" which is a split pin in the gear selector, after a bit web browsing I found out how to get it straight out, doddle when you know how :wink:
Block has gone off to be bored, honed and decked ever so slightly.
good luck
although none of the pics are showing for me
edit: make that the pics in the first 2 posts aren't
I couldn't see the first lot of pictures, lots of red x's. You seem to be getting on well with it, keep up the good work! B series engines seem so much easier to work on than the H and Ks!
I thought you had a red UK integra, or is that someone else on here (or did you sell it?)
Half the pictures aren't showing. I'm really starting to lose it with fotki now![]()
