I haven't googled it (yet), but do you (or anyone) happen to know the difference between a H570 and a B560?
Is one more advantageous than the other?
Correct me if I'm wrong but the B560 i think can only OC memory, H570 cannot?
I went with the Thermaltake Tower 100. Now it’s not the smallest case in ITX terms but it’s just lovely to look at. Looks like a little vending machine hahaWhat case did you choose? Thinking of the H210.
Was tempted to get the 11600K but not sure if a B560 chipset can be used to OC a K series, only mem speed.
Might just get the 11400 if that's the case.
The difference was £5ish and the H570 included rear 10gb USB ports. That's about it. Memory overclocking works fine on H570.
https://www.asrock.com/MB/Intel/H570M Pro4/index.asp#Specification
https://www.asrock.com/MB/Intel/B560M Pro4/index.asp
I would have been fine with either, but the H570 was in stock.
Hi all, just looking to finally upgrade from a 4790K (like someone else in this thread) and I think I will go for a B560i board. I'm not totally up to speed on which RAM to select, any suggestions (especially with speed? Don't need/want RGB!) I will be going for 16Gb I think.
Any DDR4 3200MHz kits will suffice, currently looking at the ASUS ROG B560-I for £159.98 but would like more options so may delay for a few weeks.
the asrock was one of the few in stock when I ordered. It has its own issues though. The main one being only one of the three fan headers can detect 3 pin fans being connected. The result of this is that you either have to use all pwm fans or a splitter. Problem is that I have a pwm aio attached that depends on pwm for correct operation and the fans just run at 100% all of the time as there is no DC control.
It’s not the end of the world, I purchased a couple of pwm fans but the aio fan is an rgb model. It’s quite annoying actually.
If you're getting a cheaper 10th gen, there's this board in b-grade I was tempted by.
https://www.overclockers.co.uk/b-gr...200-ddr4-micro-atx-motherboard-bg-5bt-gi.html
IO shield is built in, so no chance of it being a missing 'accessory'.
Why the 10th gen still get the unlocked memory on the b560 and at least 2 m2 slots on most of the boards
Yeah, and that's a good idea as well.
And being limited to 2666 speed ram isn't great.
And b460 can't take 11th gen in the future if you wanted to upgrade.
On the other hand, £70 is cheaper that any of the b560s. Has 2 X m.2 from the chipset, where most b560s have 1 from the CPU that would be disabled + 1 from the chipset. And some other features that lower end b560 boards don't have.
Your call but would rather pay £30 more for the faster memory and the option on three m2 drives if I did put a 11th gen in at a later date
My call in the end was 11400 + H570. Just put it out there for anyone who picks up a bargain 10th gen.
Just pulled the trigger on the i5-1140 but still undecided on a board, not many options yet.
Any ideas on availability?
Nice. Did you get free games?
The boards I think are going quick. I had the last in stock of mine.
Just received the voucher code as i typed.
Both Asus and Asrock seem to be the first on scene early, but awaiting more options from Gigabyte and MSI.
Thinking of pairing the CPU with this memory:
My basket at Overclockers UK:
Brill. Hitman or the Anno one?
Yeah, looks like a good kit. 2 x dual rank sticks is probably ideal for a 2 slot board, but would probs cost a lot more.
Anno 1800, need to make an account to access the other titles which i haven't done yet.
Not set on the memory but have been looking for a decent deal, 3200/3600 kits depending on prices.
